[OpenLayers-Dev] NASA World Wind in Openlayers
Nathan Gerber
ngerber999 at gmail.com
Wed Nov 17 10:57:04 EST 2010
The layers are likely in the zoomify format so you may want to research how
to use zoomify layers in OpenLayers.
Nathan Gerber
On Tue, Nov 16, 2010 at 6:32 PM, <maw269 at gmail.com> wrote:
> Thank You Nathan...I now have access the the NASA WMS in openlayers!
> Any idea on how I would use the downloaded data pack in openlayers? Is that
> possible?
> On Nov 15, 2010 7:48pm, Nathan Gerber <ngerber999 at gmail.com> wrote:
> > Matt,
> > For using the World Wind WMS layers you referenced this is what you would
> add to your map assuming that you are using the default projection for
> OpenLayers (EPSG:4326)
> > var nasa = new OpenLayers.Layer.WMS("NASA WMS Service",
> > "http://onearth.jpl.nasa.gov/wms.cgi?",
> > layers: 'global_mosaic'
> > , styles: 'visual'
> > tileSize: new OpenLayers.Size(512,512)
> > map.addLayer(nasa);
> > In the link you posted go to the "GetTileService" When you view the XML
> take note of the comments in the TilePattern tags. For example:
> request=GetMap&layers=daily_afternoon&srs=EPSG:4326&format=image/jpeg&styles=visual&width=512&height=512&bbox=-180,-166,76,90
> > In the above example you would take layers=daily_afternoon and use the
> daily_afternoon as your layers in the OpenLayers definition. Styles is not
> necessary unless you are looking for a specific theme. If so look in the
> above example string again and you will see styles=visual, visual is what
> you would specify in the styles definition for OpenLayers. Be sure you use
> the tileSize definition that matches the width and height from the
> TilePattern string.
> > The WorldWind example you reference is accessing the remote WorldWind
> server for the tiles. It is not intended for accessing a copy of the data
> that you downloaded.
> > Nathan Gerber
> > On Mon, Nov 15, 2010 at 4:33 PM, maw269 at gmail.com> wrote:
> > I have 2 questions:
> > 1. Is it possible to show World Wind WMS Layers from OpenLayers as in
> http://onearth.jpl.nasa.gov/tiled.html?
> > I can hit their wms from my browser:
> http://wms.jpl.nasa.gov/wms.cgi?request=GetMap&layers=global_mosaic&srs=EPSG:4326&format=image/jpeg&styles=visual&width=512&height=512&bbox=-180,-166,76,90
> > but can't seem to connect to it using any of the
> openlayers.layer.classes.
> > 2. I also downloaded the NLT Landsat 7 Visible Color-Level 0 cache pack
> from http://www.worldwinddata.com/
> > How do I use OpenLayers.Layer.WorldWind to show that layer? I looked at
> http://openlayers.org/dev/examples/worldwind.html but was even more
> confused after looking at that page's source.
> > The cache pack uzipped to my harddrive as a folder entitled '0';
> subfolders entitled '0015' through '0075'; and then images such as
> '0015_0046.jpg'
> > Thanks,
> > Matt
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101117/bb5a9bab/attachment-0001.html
More information about the Dev
