[OpenLayers-Dev] NASA World Wind in Openlayers
maw269 at gmail.com
maw269 at gmail.com
Tue Nov 16 18:32:19 EST 2010
Thank You Nathan...I now have access the the NASA WMS in openlayers!
Any idea on how I would use the downloaded data pack in openlayers? Is that
possible?
On Nov 15, 2010 7:48pm, Nathan Gerber <ngerber999 at gmail.com> wrote:
> Matt,
> For using the World Wind WMS layers you referenced this is what you would
> add to your map assuming that you are using the default projection for
> OpenLayers (EPSG:4326)
> var nasa = new OpenLayers.Layer.WMS("NASA WMS Service",
> "http://onearth.jpl.nasa.gov/wms.cgi?",
> layers: 'global_mosaic'
> , styles: 'visual'
> tileSize: new OpenLayers.Size(512,512)
> map.addLayer(nasa);
> In the link you posted go to the "GetTileService" When you view the XML
> take note of the comments in the TilePattern tags. For example:
> request=GetMap&layers=daily_afternoon&srs=EPSG:4326&format=image/jpeg&styles=visual&width=512&height=512&bbox=-180,-166,76,90
> In the above example you would take layers=daily_afternoon and use the
> daily_afternoon as your layers in the OpenLayers definition. Styles is
> not necessary unless you are looking for a specific theme. If so look in
> the above example string again and you will see styles=visual, visual is
> what you would specify in the styles definition for OpenLayers. Be sure
> you use the tileSize definition that matches the width and height from
> the TilePattern string.
> The WorldWind example you reference is accessing the remote WorldWind
> server for the tiles. It is not intended for accessing a copy of the data
> that you downloaded.
> Nathan Gerber
> On Mon, Nov 15, 2010 at 4:33 PM, maw269 at gmail.com> wrote:
> I have 2 questions:
> 1. Is it possible to show World Wind WMS Layers from OpenLayers as in
> http://onearth.jpl.nasa.gov/tiled.html?
> I can hit their wms from my browser:
> http://wms.jpl.nasa.gov/wms.cgi?request=GetMap&layers=global_mosaic&srs=EPSG:4326&format=image/jpeg&styles=visual&width=512&height=512&bbox=-180,-166,76,90
> but can't seem to connect to it using any of the openlayers.layer.classes.
> 2. I also downloaded the NLT Landsat 7 Visible Color-Level 0 cache pack
> from http://www.worldwinddata.com/
> How do I use OpenLayers.Layer.WorldWind to show that layer? I looked at
> http://openlayers.org/dev/examples/worldwind.html but was even more
> confused after looking at that page's source.
> The cache pack uzipped to my harddrive as a folder entitled '0';
> subfolders entitled '0015' through '0075'; and then images such
> as '0015_0046.jpg'
> Thanks,
> Matt
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101116/1c92f31c/attachment.html
More information about the Dev
