[OpenLayers-Dev] Remove symbols in Openstreetmap with OpenLayers
Jonathan Toledo jtoledo at prosys.cl
Wed Nov 24 16:06:14 EST 2010
Thanks for your answer. very dificult, but not impossible.
On Wed, Nov 24, 2010 at 5:33 PM, Matthew Wechsler <maw269 at gmail.com> wrote:
> Hi Jonathan,
> I don't believe you will be able to remove those symbols without
> rendering your own OSM tiles.
> If you have or are planning on redering your own map tiles and plan on
> using Mapnik you could either:
> 1. replace the .png in the mapnik>symbols folder with a 100%
> transparent file of the same name (probably safest but uglies route)
> or
> 2. Find the symbol within the symbols folder then remove all
> references of that symbol from the osm.xml file you create.
> See http://wiki.openstreetmap.org/wiki/Mapnik on how to create your own
> tiles.
> Matt
> On Wed, Nov 24, 2010 at 3:04 PM, Jonathan Toledo <jtoledo at prosys.cl>
> wrote:
> > Hi. My question is very simple to understand. I need to remove some
> symbols
> > in Openstreetmap, like restorants, parkin, etc. Here's a picture:
> > http://img52.imageshack.us/img52/3198/openstreetmap.png
> > Thanks.
> > Jonathan M. Toledo Orobia
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101124/8878ca09/attachment.html
More information about the Dev mailing list
