[OpenLayers-Dev] Standardized icons and CSS for use in Panels
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sun Oct 24 11:01:47 EDT 2010
Hi list,
Now to mount a panel is necessary write CSS for the icons. This can be seen
in some OpenLayers examples; also the users are faced with the same
difficulty. And OL icons are scattered, and many of them do not have
transparency in the corners (see "EditingToolbar.html" example on the sea)
I think it would be good delivered most common icons grouped, and have a CSS
so that icons can be used directly.
In the patch http://trac.osgeo.org/openlayers/ticket/2863 I propose common
icons grouped with CSS to handle, and include changes in "style.css" to use
these icons on "NavToolbar" and "EditingToolbar"
The patch includes an example that shows the list of icons.
Would like to know whose opinion deserves this kind of work, thanks.
Xavier
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Standardized-icons-and-CSS-for-use-in-Panels-tp5667841p5667841.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
