[OpenLayers-Dev] The tickets #2835 #2850 and #2864 collided with #2868
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Oct 26 13:00:52 EDT 2010
Hi list,
The situation now is:
 * #2835 partially implemented.
 * #2850 not fixed, and now fails the test.
 * #2864 closed without fixing the bug, is pending #2210
 * #2210 needs more work, due to problems with #2835
Analyzing the collision can see that #2835 #2850 and #2864 are correct. The
http://osgeo-org.1803224.n2.nabble.com/file/n5675525/2864-2850-2835.patch
2864-2850-2835.patch  attached passes the tests of all controls.
… and the http://trac.osgeo.org/openlayers/ticket/2210#comment:3 should be
reconsidered; the
2864-2850-2835.patch  solve the problem.
Regards,
Xavier
View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-tickets-2835-2850-and-2864-collided-with-2868-tp5675525p5675525.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
