[OpenLayers-Dev] Maximum number of tiles requested
DGIS Devels
webgisdesarrollo at gmail.com
Mon Sep 13 04:13:26 EDT 2010
Thanks Peter. We didn't know this limit is so small. I'm not sure but in
Firefox seems to be of 4 parallel requests, isn't?
2010/9/10 Peter Körner <osm-lists at mazdermind.de>
> Am 10.09.2010 14:42, schrieb DGIS Devels:
> Is the number of tiles requested simultaneously limited in OpenLayers? I
>> would like to know how long I have to wait (timeout) to have a whole map
>> with a high number of tiles.
> Most browsers have a hard-coded limit of 2 parallel Requests per Domain to
> avoid flooding servers with requests.
> The limit is per Domain, not per IP, which is why you can trick around this
> limit by using multiple domains to point to your tile-server (
> a.tile.myserver.net, b.tile.myserver.net, c.tile.myserver.net).
> If is, for example, done on osm.org:
> http://www.openstreetmap.org/openlayers/OpenStreetMap.js
> Peter
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100913/c16db6f8/attachment.html
More information about the Dev
