[OpenLayers-Dev] Question: Vector layer with draw & modify feature
Moiz Bhukhiya
moiz.bhukhiya at gmail.com
Wed Sep 15 05:32:29 EDT 2010
I am using vector (polygon) layer with draw feature and modify feature. Let
me explain first what I am trying to achieve. I want to draw
rectangles(strict horizontally aligned) and after drawing it might require a
little bit of modification but again it shouldn't lose its shape.
Here is what I tried doing:
polygonLayer = new OpenLayers.Layer.Vector("Capture Region",
{displayInLayerSwitcher: true, reproject: true});
polyOptions = {sides: 4, snapAngle: 180, irregular: true}; //To draw
only rectangles
var pan = new OpenLayers.Control.Navigation({title: "Navigate"})
polygonControl = new OpenLayers.Control.DrawFeature(polygonLayer,
OpenLayers.Handler.RegularPolygon,
{handlerOptions: polyOptions});
modify = new OpenLayers.Control.ModifyFeature(
polygonLayer, {displayClass: "olControlModifyFeature",
title: "Modify Features"},
{mode: ~OpenLayers.Control.ModifyFeature.RESHAPE |
OpenLayers.Control.ModifyFeature.RESIZE
| OpenLayers.Control.ModifyFeature.DRAG }
var panel = new OpenLayers.Control.Panel({
displayClass: "olControlEditingToolbar"
panel.addControls([pan, polygonControl, modify]);
map.addControl(panel);
The problem is it doesn't follow the modify feature modes I have defined. It
allows reshaping and doesn't allow dragging and resizing. Another problem I
have is when I define the displayClass for draw feature, it wouldn't let me
draw rectangles that are horizontally aligned. To point your attention
towards where I might be making a mistake, I am using
OpenLayers.Handler.RegularPolygon to draw feature. Is that a problem?
Thanks a lot for taking time to read my problem and I'd really appreciate if
you could help me with any suggestions and ideas.
Thanks!
Moiz
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100915/70ebad55/attachment.html
More information about the Dev
