[OpenLayers-Dev] Re: [OpenLayers] #2819: Format.XML could add xmlns
attributes by default
Xurxo Mendez
sonxurxo at gmail.com
Fri Apr 1 11:25:20 EDT 2011
Yes it's been some months since I wrote the patch and I'm not an expert in
OpenLayers way of working with XML, I just faced a specific problem with SOS
then and tried to fix it, so it's ok to bump it to 2.12. Thanks for reviews
Best regards,
Xurxo Méndez Pérez
http://blog.sonxurxo.com
http://www.sonxurxo.com
2011/4/1 OpenLayers <trac-20090302 at openlayers.org>
> #2819: Format.XML could add xmlns attributes by default
> Reporter: bartvde | Owner: erilem
> Type: feature | Status: new
> Priority: minor | Milestone: 2.12 Release
> Component: Format.XML | Version: 2.10 RC1
> Keywords: | State: Needs More Work
> Comment(by bartvde):
> And there is a workaround for this issue (e.g. used in the SOS code),
> which justifies bumping it for now.
> Ticket URL: <http://trac.openlayers.org/ticket/2819#comment:10>
> OpenLayers <http://openlayers.org/>
> A free AJAX map viewer
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110401/ec5987e6/attachment-0001.html
More information about the Dev
