[OpenLayers-Dev] VERSION_NUMBER
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Apr 4 12:23:32 EDT 2011
On Monday, April 4, 2011, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi list,
> I see that in trunk VERSION_NUMBER now occurs in 2 files:
> * OpenLayers.js
> * OpenLayers/SingleFile.js
> However their values differ.
> Is this not gonna lead to confusion?
If I read the release procedure correctly both
OpenLayers.VERSION_NUMBER values are manually set to "Release-x.y" in
the SVN tag. So no confusion for releases.
In trunk we use the $Revision$ keyword, so you're right, the values in
OpenLayers.js and SingleFile.js differ. I'm not sure I understand the
purpose of using $Revision$ here, as the latter is the revision number
in which the file (OpenLayers.js or SingleFile.js) changed. So, to me,
the VERSION_NUMBER string has no valuable meaning for the trunk.
Please correct me if I'm wrong.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
