[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior changes
Eric Lemoine eric.lemoine at camptocamp.com
Tue Aug 2 09:54:30 EDT 2011
On Tue, Aug 2, 2011 at 3:23 PM, RICHARD Didier <didier.richard at ign.fr> wrote:
>> On Tue, Aug 2, 2011 at 12:54 PM, RICHARD Didier <didier.richard at ign.fr>
>> wrote:
>>>>> This test has been ran on FF successfully.
>>>> I haven't looked at your tests into detail, but do mean your problems
>>>> are now solved?
>>> no, just meant it works with OL 2.11 under FF ... I have got problems
>>> with
>>> OL 2.10 !
>> I fail to see where you're having problem. Sorry.
> What about these cases ?
> 1/ var A= OpenLayers.Class({...})
> A.staticFunction= function() { ... };
> A= overload(A, { initialize: function() {...}});
See my changes to the overload function, and test_overload_6.
> 2/ in test 4, if you remove the initialize function from B and overload A,
> the B constructor is still the previous A's constructor.
Yes. To address this one I see no other solution than patching
OpenLayers.Class. See the patch attached to this email, and my
test_overload_5 test function. The Class.html tests continue to pass
with my patch.
<html>
<head>
  <!--<script src="http://openlayers.org/api/2.10/OpenLayers.js"></script>-->
  <!--<script src="http://openlayers.org/dev/OpenLayers.js"></script>-->
  <script src="OLLoader.js"></script>
  <script type="text/javascript">
    // the overload function under test
    function overload(C, o) {
        if(typeof o.initialize === "function" &&
            C === C.prototype.initialize) {
            // OL 2.11
            var proto = C.prototype;
            var staticProps = OpenLayers.Util.extend({}, C);
            C = o.initialize;
            C.prototype = proto;
            OpenLayers.Util.extend(C, staticProps);
        OpenLayers.Util.extend(C.prototype, o);
        return C;
    function test_overload_1(t) {
        // overload constructor
        t.plan(1);
        var A = OpenLayers.Class({
                this.a = "foo";
        A = overload(A, {
                this.a = "bar";
        var a = new A;
        t.eq(a.a, "bar", "ctor overloaded");
    function test_overload_2(t) {
        // overload regular method
        t.plan(1);
            method: function() {
                this.a = "foo";
        A = overload(A, {
                this.a = "bar";
        var a = new A;
        a.method();
        t.eq(a.a, "bar", "method overloaded");
    function test_overload_3(t) {
        // overload constructor of subclass
        t.plan(1);
                this.a = "foo";
        var B = OpenLayers.Class(A, {
                A.prototype.initialize.call(this);
        B = overload(B, {
                this.a = "bar";
        var b = new B;
        t.eq(b.a, "bar", "ctor overloaded");
    function test_overload_4(t) {
        // overload constructor of parent class
        t.plan(1);
                this.a = "foo";
        A = overload(A, {
                this.a = "bar";
        var b = new B;
    function test_overload_5(t) {
        t.plan(1);
                this.a = "foo";
        var B = OpenLayers.Class(A, {});
        A = overload(A, {
                this.a = "bar";
        var b = new B;
    function test_overload_6(t) {
        // with static methods
        t.plan(1);
        A.staticMethod = function() {};
        A = overload(A, {
        var exc = false;
        try {
            A.staticMethod();
        } catch(e) {
            exc = true;
        t.ok(!exc, "static method still there");
  </script>
</head>
<body>
</body>
</html>
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110802/3503e3d3/overload.html
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110802/3503e3d3/Class.bin
More information about the Dev mailing list
