[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior
changes
RICHARD Didier
didier.richard at ign.fr
Wed Aug 3 08:06:17 EDT 2011
> On Tue, Aug 2, 2011 at 3:23 PM, RICHARD Didier <didier.richard at ign.fr>
> wrote:
>>> On Tue, Aug 2, 2011 at 12:54 PM, RICHARD Didier <didier.richard at ign.fr>
>>> wrote:
>>>>>> This test has been ran on FF successfully.
>>>>> I haven't looked at your tests into detail, but do mean your problems
>>>>> are now solved?
>>>> no, just meant it works with OL 2.11 under FF ... I have got problems
>>>> with
>>>> OL 2.10 !
>>> I fail to see where you're having problem. Sorry.
>> What about these cases ?
>> 1/ var A= OpenLayers.Class({...})
>> A.staticFunction= function() { ... };
>> A= overload(A, { initialize: function() {...}});
> See my changes to the overload function, and test_overload_6.
Ok, this works for me too (OL 2.10/2.11-rc1)
>> 2/ in test 4, if you remove the initialize function from B and overload
>> A,
>> the B constructor is still the previous A's constructor.
> Yes. To address this one I see no other solution than patching
> OpenLayers.Class. See the patch attached to this email, and my
> test_overload_5 test function. The Class.html tests continue to pass
> with my patch.
this works in OL 2.11, not in OL 2.10 for me !-(
I guess there is something similar to do in OL 2.10 ?
Regards,
didier
> <html>
> <head>
> <!--<script
> src="http://openlayers.org/api/2.10/OpenLayers.js"></script>-->
> <!--<script src="http://openlayers.org/dev/OpenLayers.js"></script>-->
> <script src="OLLoader.js"></script>
> <script type="text/javascript">
> // the overload function under test
> function overload(C, o) {
> if(typeof o.initialize === "function" &&
> C === C.prototype.initialize) {
> // OL 2.11
> var proto = C.prototype;
> var staticProps = OpenLayers.Util.extend({}, C);
> C = o.initialize;
> C.prototype = proto;
> OpenLayers.Util.extend(C, staticProps);
> OpenLayers.Util.extend(C.prototype, o);
> return C;
> function test_overload_1(t) {
> // overload constructor
> t.plan(1);
> var A = OpenLayers.Class({
> this.a = "foo";
> A = overload(A, {
> this.a = "bar";
> var a = new A;
> t.eq(a.a, "bar", "ctor overloaded");
> function test_overload_2(t) {
> // overload regular method
> t.plan(1);
> method: function() {
> this.a = "foo";
> A = overload(A, {
> this.a = "bar";
> var a = new A;
> a.method();
> t.eq(a.a, "bar", "method overloaded");
> function test_overload_3(t) {
> // overload constructor of subclass
> t.plan(1);
> this.a = "foo";
> var B = OpenLayers.Class(A, {
> A.prototype.initialize.call(this);
> B = overload(B, {
> this.a = "bar";
> var b = new B;
> t.eq(b.a, "bar", "ctor overloaded");
> function test_overload_4(t) {
> // overload constructor of parent class
> t.plan(1);
> this.a = "foo";
> A = overload(A, {
> this.a = "bar";
> var b = new B;
> function test_overload_5(t) {
> t.plan(1);
> this.a = "foo";
> var B = OpenLayers.Class(A, {});
> A = overload(A, {
> this.a = "bar";
> var b = new B;
> function test_overload_6(t) {
> // with static methods
> t.plan(1);
> A.staticMethod = function() {};
> A = overload(A, {
> var exc = false;
> try {
> A.staticMethod();
> } catch(e) {
> exc = true;
> t.ok(!exc, "static method still there");
> </script>
> </head>
> <body>
> </body>
> </html>
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
RICHARD Didier - Chef du pôle technique du Géoportail
2/4, avenue Pasteur - 94165 Saint Mandé Cedex
Tél : +33 (0) 1 43 98 83 23
More information about the Dev
