[OpenLayers-Dev] Problem using WMS Post + sld_body + singleTile:true
Davi Custódio
Davicustodio at gmail.com
Sun Aug 7 19:49:40 EDT 2011
Hello all,
My problem is relation to a use of a layer WMS Post with the singleTite:
true, that makes a layer that is using sld_body, behaves strangely ... I
have tried several alternatives. Using wms.post after using tileOptions:
maxGetUrlLength {2048}, but the problem persists. Interestingly, for the
layers that have sld_body, who are using singleTile: false, do a Zoom or
Pan, and possibly randomly OpenLayers does not clear the cache and leaves a
trail that is not quenched. Now for the layers that use singleTile: true, a
strange thing happens in the transition effect, repainting the tiles before
setting up completely before the new tiles (or after a zoom or pan). For a
layer that uses singleTile: true, using Chrome, it works OK. But for the
IEs, Firefox and Safari, the problem of transition strange happens. I also
tried using transitionEffect: 'default' and did not work. Do you think there
is still no solution to this bug related to layers containing sld_body and
use singleTile: true? Thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-using-WMS-Post-sld-body-singleTile-true-tp6662685p6662685.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
