[OpenLayers-Dev] Problem using WMS Post + sld_body +
singleTile:true
Andreas Hocevar
ahocevar at opengeo.org
Mon Aug 8 04:40:58 EDT 2011
are you working with OpenLayers 2.11-rc1 or trunk? If so, can you please apply the patch attached to http://trac.osgeo.openlayers.org/ticket/3419 and see if this resolves your issue?
Thanks,
Andreas.
On Aug 8, 2011, at 01:49 , Davi Custódio wrote:
> Hello all,
> My problem is relation to a use of a layer WMS Post with the singleTite:
> true, that makes a layer that is using sld_body, behaves strangely ... I
> have tried several alternatives. Using wms.post after using tileOptions:
> maxGetUrlLength {2048}, but the problem persists. Interestingly, for the
> layers that have sld_body, who are using singleTile: false, do a Zoom or
> Pan, and possibly randomly OpenLayers does not clear the cache and leaves a
> trail that is not quenched. Now for the layers that use singleTile: true, a
> strange thing happens in the transition effect, repainting the tiles before
> setting up completely before the new tiles (or after a zoom or pan). For a
> layer that uses singleTile: true, using Chrome, it works OK. But for the
> IEs, Firefox and Safari, the problem of transition strange happens. I also
> tried using transitionEffect: 'default' and did not work. Do you think there
> is still no solution to this bug related to layers containing sld_body and
> use singleTile: true? Thank you.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-using-WMS-Post-sld-body-singleTile-true-tp6662685p6662685.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
