[OpenLayers-Dev] Re: Problems with freehand drawing in 2.11
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Mon Aug 8 14:53:55 EDT 2011
You can test if this change works:
http://trac.osgeo.org/openlayers/attachment/ticket/3456/touch-freehand-3456.patch
Xavier Mamano
Kenny Lam wrote:
> Hi,
> I'm having problems with any sorts of freehand drawing on a mobile
> platform
> with 2.11. I haven't had any success with a potential solution, and it
> either passes the motion into the browser window itself and pans the
> browser
> app or does nothing, but clearly tries to keep up with the tapped
> position.
> I'm using the handlers from polygon and path, and neither seems to work
> right. Any solutions?
> Thanks.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-freehand-drawing-in-2-11-tp6649961p6665438.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
