[OpenLayers-Dev] Re: Problems with freehand drawing in 2.11
Kenny Lam
khl1392 at gmail.com
Tue Aug 9 13:00:39 EDT 2011
The patch
http://trac.osgeo.org/openlayers/attachment/ticket/3456/touch-freehand-3456.patch
for freehand drawing on mobile devices works!
However, the shape isn't visible while it's being drawn, only after you've
completed the drawing (i.e. lifted your finger).
Thanks again.
On Wed, Aug 3, 2011 at 3:41 PM, Kenny Lam <khl1392 at gmail.com> wrote:
> Hi,
> I'm having problems with any sorts of freehand drawing on a mobile platform
> with 2.11. I haven't had any success with a potential solution, and it
> either passes the motion into the browser window itself and pans the browser
> app or does nothing, but clearly tries to keep up with the tapped position.
> I'm using the handlers from polygon and path, and neither seems to work
> right. Any solutions?
> Thanks.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110809/5d7b7aa9/attachment-0001.html
More information about the Dev
