[OpenLayers-Dev] Re: How to override abstract
OpenLayers.Protocol.WFS.v1?
Andreas Hocevar
ahocevar at opengeo.org
Wed Aug 10 10:35:37 EDT 2011
no worries, everybody's out there, busy improving OpenLayers. Using the new Class.js file with older versions of OpenLayers shouldn't be a problem. An update to latest OpenLayers would be the best option of course, so you get the latest and greatest.
Andreas.
On Aug 10, 2011, at 16:31 , myOpenLayersUName wrote:
> The problem seems to be how the Class.js class is defined in the release
> versions of OpenLayers.
> If I replace the BaseTypes/Class.js in OpenLayers 2.8 and/or 2.10 with the
> BaseTypes/Class.js distributed with 2.11, I am able to override the
> OpenLayers.Protocol.WFS.v1 as expected.
> Is anyone (assuming there is anyone out there, which at this point I'm
> really not sure is the case) aware of any bad implications in our doing
> this? So far I haven't seen any, but I haven't done any major testing with
> this change yet either?
> Cheers,
> jtm
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-override-abstract-OpenLayers-Protocol-WFS-v1-tp6534072p6672601.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
