[OpenLayers-Dev] Re: Problems with freehand drawing in 2.11
Xavier Mamano (jorix) xavier.mamano at gmail.com
Fri Aug 12 17:49:55 EDT 2011
Hi Kenny,
You can test this new patch:
http://trac.osgeo.org/openlayers/attachment/ticket/3456/touch-freehand-3456.2.patch
With this new patch the shape is always displayed (in my tests)
You can test if the patch works for you?
Xavier
Kenny Lam wrote:
> Hi Xavier,
> Right now, I've done testing on Android 2.2 and 2.3 for both the original
> problem and the patch fix. I encountered the original problem on  iOS 4,
> but
> haven't since tried the patch yet.
> Thanks so much for your help so far though!
> On Tue, Aug 9, 2011 at 1:00 PM, Kenny Lam <khl1392 at gmail.com> wrote:
>> The patch
>> http://trac.osgeo.org/openlayers/attachment/ticket/3456/touch-freehand-3456.patch
>> for freehand drawing on mobile devices works!
>> However, the shape isn't visible while it's being drawn, only after
>> you've
>> completed the drawing (i.e. lifted your finger).
>> Thanks again.
>> On Wed, Aug 3, 2011 at 3:41 PM, Kenny Lam <khl1392 at gmail.com>
>> wrote:
>>> Hi,
>>> I'm having problems with any sorts of freehand drawing on a mobile
>>> platform with 2.11. I haven't had any success with a potential solution,
>>> and
>>> it either passes the motion into the browser window itself and pans the
>>> browser app or does nothing, but clearly tries to keep up with the
>>> tapped
>>> position. I'm using the handlers from polygon and path, and neither
>>> seems to
>>> work right. Any solutions?
>>> Thanks.
> Kenny H. Lam
> Massachusetts Institute of Technology
> Department of Physics | Class of 2013
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-freehand-drawing-in-2-11-tp6649961p6681872.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
