[OpenLayers-Dev] Re: Openlayers and Fusion table?
Noli Sicad
nsicad at gmail.com
Fri Aug 19 19:58:19 EDT 2011
This is doc for GFT - Google Fusion Tables GDAL/OGR.
This driver can connect to the Google Fusion Tables service. GDAL/OGR
must be built with Curl support in order to the GFT driver to be
compiled.
http://www.gdal.org/ogr/drv_gft.html
I hope Openlayers will support Fusion Tables.
Thanks.
Noli
On 8/19/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi,
> It seems that fusion table with SQL queries is nice feature in Google Maps.
> For example:
> layer = new google.maps.FusionTablesLayer(tableid);
> layer.setQuery("SELECT 'geometry' FROM " + tableid);
> layer.setMap(map);
> layer2 = new google.maps.FusionTablesLayer(tableid2);
> layer2.setQuery("SELECT 'geometry' FROM " + tableid2 + " WHERE
> California");
> layer2.setMap(map);
> http://www.advocacy.ucla.edu/Maps/Assembly_map.html
> Could we use fusion tables in Openlayers? Any example / demo how to
> use fusion tables with Openlayers?
> Anything plan similar (i.e. Fusion table) in Openlayers in the area?
> Noli
More information about the Dev
