[OpenLayers-Dev] Re: Openlayers and Fusion table?
Noli Sicad
nsicad at gmail.com
Fri Aug 19 20:08:59 EDT 2011
Look what I found - OpenLayers with Fusion Tables using GeoJSON.
http://maps.peterrobins.co.uk/files/ol3a.html
http://groups.google.com/group/fusion-tables-users-group/browse_thread/thread/caef336c62ee8c0e/d55662e2aea37b99
Hope OL dev team can create example out of this.
Noli
On 8/20/11, Noli Sicad <nsicad at gmail.com> wrote:
> This is doc for GFT - Google Fusion Tables GDAL/OGR.
> This driver can connect to the Google Fusion Tables service. GDAL/OGR
> must be built with Curl support in order to the GFT driver to be
> compiled.
> http://www.gdal.org/ogr/drv_gft.html
> I hope Openlayers will support Fusion Tables.
> Thanks.
> Noli
> On 8/19/11, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>> It seems that fusion table with SQL queries is nice feature in Google
>> Maps.
>> For example:
>> layer = new google.maps.FusionTablesLayer(tableid);
>> layer.setQuery("SELECT 'geometry' FROM " + tableid);
>> layer.setMap(map);
>> layer2 = new google.maps.FusionTablesLayer(tableid2);
>> layer2.setQuery("SELECT 'geometry' FROM " + tableid2 + " WHERE
>> California");
>> layer2.setMap(map);
>> http://www.advocacy.ucla.edu/Maps/Assembly_map.html
>> Could we use fusion tables in Openlayers? Any example / demo how to
>> use fusion tables with Openlayers?
>> Anything plan similar (i.e. Fusion table) in Openlayers in the area?
>> Noli
More information about the Dev
