[OpenLayers-Dev] OpenLayers 2.11 RC2
Bart van den Eijnden
bartvde at osgis.nl
Mon Aug 22 06:18:00 EDT 2011
Hi Didier,
I believe this was reverted after RC2, see also:
http://trac.osgeo.org/openlayers/ticket/3431
Would be good to test with either trunk or the to be released RC3.
TIA.
Best regards,
Bart
OSGIS - http://osgis.nl
On Aug 21, 2011, at 4:07 PM, RICHARD Didier wrote:
>> The full build was also failing (on some systems) due to a missing
>> requires.
>> http://trac.osgeo.org/openlayers/ticket/3467
>> Please pull this into RC3 as well.
> Hi all,
> I may have another regression between OL 2.10 and OL 2.11 RC2 :
> * OL 2.10 :
> OpenLayers.Layer.setOpacity() : the inner divs are changed when modifying
> the layer's opacity
> * OL 2.11 :
> the layer's opacity seems to be now managed at the layer's div directly.
> If we have a look at OpenLayers.Tile.Image.initImgDiv() method, one can
> find :
> if(this.layer.opacity != null) {
> OpenLayers.Util.modifyDOMElement(this.imgDiv, null, null, null,
> null, null, null,
> this.layer.opacity);
> when the tile's div is created.
> Calling layer.setOpacity() does not change the tile's opacity anymore (in
> fact, if you start with an opacity of 30%, then you have got 30% on the
> layer's div and 30% on the tile's opacity ...).
> I guess the above lines could be removed from initImgDiv(). Don't know
> whether there are other pitfalls related with the new opacity management.
> Any thought on that ?
> didier
>> Thanks,
>> Tim
>> On Mon, Aug 15, 2011 at 4:16 PM, <christopher.schmidt at nokia.com> wrote:
>>> We have a clear regression that will force an RC3. I'm willing to pull
>>> this
>>> into the RC3.
>>> It looks like there's still a few outstanding bugs against RC2. I'll
>>> leave
>>> those open for another day or two, but if there's not more done on them,
>>> then I'm likely to proceed without waiting on further fixes, barring
>>> additional regressions.
>>> -- Chris
>>> On Aug 15, 2011, at 8:33 PM, ext Tim Schaub wrote:
>>>> I committed Volker's patch for
>>>> http://trac.osgeo.org/openlayers/ticket/3417
>>>> I've added my thoughts on the ticket. I'll leave it up to the release
>>>> manager to decide if this is pulled into another RC. We have to stop
>>>> at some point, and I think we'd all agree that only a clear regression
>>>> should warrant a new RC.
>>>> Thanks for the patch Volker. Sorry I didn't pick it up immediately
>>>> after we talked about it some weeks ago.
>>>> Tim
>>>> On 8/14/11 11:07 AM, Volker Mische wrote:
>>>>> On 08/08/2011 04:20 PM, christopher.schmidt at nokia.com wrote:
>>>>>> The OpenLayers Development Team is proud to announce the second
>>>>>> release
>>>>>> candidate of OpenLayers 2.11!
>>>>>> As of 2.11-RC2, the OpenLayers 2.11 release closes an additional 31
>>>>>> tickets,
>>>>>> resolving a number of issues with the previous release candidate.
>>>>>> We invite you to help us test the 2.11 release candidate! To test
>>>>>> 2.11
>>>>>> in your applications, include the following tag in your
>>>>>> OpenLayers-powered page:
>>>>>> <script
>>>>>> src="http://openlayers.org/api/2.11-rc2/OpenLayers.js"></script>
>>>>>> As always, the source is available at
>>>>>> http://openlayers.org/download/.
>>>>>> Bug reports can be filed in Trac, under the 2.11 RC2 version and 2.11
>>>>>> milestone.
>>>>> Hi all,
>>>>> I somehow missed this 2.11 RC2 mail. Is there a chance to get the
>>>>> JSONP
>>>>> (OpenLayers.Protocol.Script) improvements into 2.11?
>>>>> Is there anything I can do to make it happen?
>>>>> The reason why I really want it in is, that also CouchDB uses such
>>>>> more
>>>>> restrictive callback name validation and I'd like to make as easy as
>>>>> possible for people to use OpenLayers/MapQuery with a remote
>>>>> CouchDB/GeoCouch.
>>>>> Cheers,
>>>>> Volker
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> Dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>> Dev mailing list
>> Tim Schaub
>> OpenGeo http://opengeo.org/
>> Expert service straight from the developers.
>> Dev mailing list
> RICHARD Didier - Chef du pôle technique du Géoportail
> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
> Tél : +33 (0) 1 43 98 83 23
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110822/a30f5d09/attachment-0001.html
More information about the Dev
