[OpenLayers-Dev] OpenLayers 2.11 RC2
RICHARD Didier
didier.richard at ign.fr
Mon Aug 22 14:47:38 EDT 2011
> Hi Didier,
Hi Bart,
> I believe this was reverted after RC2, see also:
> http://trac.osgeo.org/openlayers/ticket/3431
> Would be good to test with either trunk or the to be released RC3.
I'm awaiting for RC3 in that case !
Best regards,
didier
> TIA.
> Best regards,
> Bart
> Bart van den Eijnden
> OSGIS - http://osgis.nl
> On Aug 21, 2011, at 4:07 PM, RICHARD Didier wrote:
>>> The full build was also failing (on some systems) due to a missing
>>> requires.
>>> http://trac.osgeo.org/openlayers/ticket/3467
>>> Please pull this into RC3 as well.
>> Hi all,
>> I may have another regression between OL 2.10 and OL 2.11 RC2 :
>> * OL 2.10 :
>> OpenLayers.Layer.setOpacity() : the inner divs are changed when
>> modifying
>> the layer's opacity
>> * OL 2.11 :
>> the layer's opacity seems to be now managed at the layer's div directly.
>> If we have a look at OpenLayers.Tile.Image.initImgDiv() method, one can
>> find :
>> if(this.layer.opacity != null) {
>> OpenLayers.Util.modifyDOMElement(this.imgDiv, null, null, null,
>> null, null, null,
>> this.layer.opacity);
>> when the tile's div is created.
>> Calling layer.setOpacity() does not change the tile's opacity anymore
>> (in
>> fact, if you start with an opacity of 30%, then you have got 30% on the
>> layer's div and 30% on the tile's opacity ...).
>> I guess the above lines could be removed from initImgDiv(). Don't know
>> whether there are other pitfalls related with the new opacity
>> management.
>> Any thought on that ?
>> didier
>>> Thanks,
>>> Tim
>>> On Mon, Aug 15, 2011 at 4:16 PM, <christopher.schmidt at nokia.com>
>>> wrote:
>>>> We have a clear regression that will force an RC3. I'm willing to pull
>>>> this
>>>> into the RC3.
>>>> It looks like there's still a few outstanding bugs against RC2. I'll
>>>> leave
>>>> those open for another day or two, but if there's not more done on
>>>> them,
>>>> then I'm likely to proceed without waiting on further fixes, barring
>>>> additional regressions.
>>>> -- Chris
>>>> On Aug 15, 2011, at 8:33 PM, ext Tim Schaub wrote:
>>>>> I committed Volker's patch for
>>>>> http://trac.osgeo.org/openlayers/ticket/3417
>>>>> I've added my thoughts on the ticket. I'll leave it up to the
>>>>> release
>>>>> manager to decide if this is pulled into another RC. We have to stop
>>>>> at some point, and I think we'd all agree that only a clear
>>>>> regression
>>>>> should warrant a new RC.
>>>>> Thanks for the patch Volker. Sorry I didn't pick it up immediately
>>>>> after we talked about it some weeks ago.
>>>>> Tim
>>>>> On 8/14/11 11:07 AM, Volker Mische wrote:
>>>>>> On 08/08/2011 04:20 PM, christopher.schmidt at nokia.com wrote:
>>>>>>> The OpenLayers Development Team is proud to announce the second
>>>>>>> release
>>>>>>> candidate of OpenLayers 2.11!
>>>>>>> As of 2.11-RC2, the OpenLayers 2.11 release closes an additional 31
>>>>>>> tickets,
>>>>>>> resolving a number of issues with the previous release candidate.
>>>>>>> We invite you to help us test the 2.11 release candidate! To test
>>>>>>> 2.11
>>>>>>> in your applications, include the following tag in your
>>>>>>> OpenLayers-powered page:
>>>>>>> <script
>>>>>>> src="http://openlayers.org/api/2.11-rc2/OpenLayers.js"></script>
>>>>>>> As always, the source is available at
>>>>>>> http://openlayers.org/download/.
>>>>>>> Bug reports can be filed in Trac, under the 2.11 RC2 version and
>>>>>>> 2.11
>>>>>>> milestone.
>>>>>> Hi all,
>>>>>> I somehow missed this 2.11 RC2 mail. Is there a chance to get the
>>>>>> JSONP
>>>>>> (OpenLayers.Protocol.Script) improvements into 2.11?
>>>>>> Is there anything I can do to make it happen?
>>>>>> The reason why I really want it in is, that also CouchDB uses such
>>>>>> more
>>>>>> restrictive callback name validation and I'd like to make as easy as
>>>>>> possible for people to use OpenLayers/MapQuery with a remote
>>>>>> CouchDB/GeoCouch.
>>>>>> Cheers,
>>>>>> Volker
>>>>>> _______________________________________________
>>>>>> Dev mailing list
>>>>>> Dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>> Dev mailing list
>>> Tim Schaub
>>> OpenGeo http://opengeo.org/
>>> Expert service straight from the developers.
>>> Dev mailing list
>> RICHARD Didier - Chef du pôle technique du Géoportail
>> 2/4, avenue Pasteur - 94165 Saint Mandé Cedex
>> Tél : +33 (0) 1 43 98 83 23
>> Dev mailing list
More information about the Dev
