[OpenLayers-Dev] Re: OpenLayers API doc
Björn Harrtell
bjorn.harrtell at gmail.com
Tue Aug 23 06:20:33 EDT 2011
Note that Ext JS 4 docs uses a new jsdocs-based framework* to generate the
docs where markdown syntax is prefered to HTML.
/Björn
*) https://github.com/senchalabs/jsduck
2011/8/10 Matt Priour <mpriour at kestrelcomputer.com>
> I'm sure you are correct about scripting only being able to handle the low
> hanging fruit since you have actually been working with it. Looking at
> ExtJS, YUI, and Google's closure js framework; they do have to use a LOT of
> html to get decent class and method descriptions. However, looking at
> SproutCore, they are able to use JSDoc and get decent looking descriptions
> in their API docs.
> Matt Priour
> Kestrel Computer Consulting
> http://osgeo-org.1803224.n2.nabble.com/OpenLayers-API-doc-tp6667194p6670876.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110823/ae7d853c/attachment.html
More information about the Dev
