[OpenLayers-Dev] Re: Adding Segment Length to Path
Xavier Mamano (jorix) xavier.mamano at gmail.com
Sat Dec 10 13:04:05 EST 2011
Hi Yus,
I think now it works.
You can see the solution I propose in
https://github.com/jorix/OL-DynamicMeasure
Problems:
 * Labels do not remain at the end of measure.
 * Using the freehand the map is dirtied by the labels.
 * Layer of the labels (`vlayer`) should be on top of the drawing layer.
 * Allow the use of immediate measure (new in 2.11)
Try: http://jorix.github.com/OL-DynamicMeasure/examples/measure-dynamic.html
Xavier Mamano
Yus wrote
> Hi.
> Ran into a small problem when change to OpenLayers 2.11 with showing the
> length of each segment on the measuring line.
> Previously after placing points A --> B, B --> C. The length of segment A
> to B would show up between those points, likewise with B to C and after
> ending the line the total would be displayed.
> My script worked fine with OpenLayers 2.10, but after changing to
> OpenLayers 2.11 as soon as I end the line only the segment values
> disappear from the vector layer.
> I understand the problem, but am having trouble working out the logic...
> Below is the script I am using:
> line: new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {
>     persist: true,
>     handlerOptions: {
>         layerOptions: {
>             renderers: renderer,
>             styleMap: styleMap
>     textNodes: null,
>     callbacks:{
>         create:
>         function(){
>             this.textNodes = [];
>             vlayer.destroyFeatures(vlayer.features); *<-- Believe the
> problem is here*
>             mouseMovements = 0;
>         modify:
>         function(point, line){
>             if(mouseMovements++ < 5){
>                 return;
>             var len = line.geometry.components.length;
>             var from = line.geometry.components[len -2];
>             var to = line.geometry.components[len -1];
>             var ls = new OpenLayers.Geometry.LineString([from, to]);
>             var dist = this.getBestLength(ls);
>             if(!dist[0]){
>                 return;
>             var total = this.getBestLength(line.geometry);
>             var label = dist[0].toFixed(3) + " " + dist[1];
>             var textNode = this.textNodes[len -2] || null;
>             if(textNode && !textNode.layer){
>                 this.textNodes.pop();
>                 textNode = null;
>             if(!textNode){
>                 var c = ls.getCentroid();
>                 textNode = new OpenLayers.Feature.Vector(
>                 new OpenLayers.Geometry.Point(c.x, c.y), {}, {
>                     label: "",
>                     fontColor: "#800517",
>                     fontSize: "12px",
>                     fontFamily: "Tahoma",
>                     fontWeight: "bold",
>                     labelAlign: "cm"
>                 this.textNodes.push(textNode);
>                 vlayer.addFeatures([textNode]);
>             textNode.geometry.x = (from.x + to.x) / 2;
>             textNode.geometry.y = (from.y + to.y) / 2;
>             textNode.style.label = label;
>             textNode.layer.drawFeature(textNode);
>             this.events.triggerEvent("measuredynamic", {
>                 measure: dist[0],
>                 total: total[0],
>                 units: dist[1],
>                 order: 1,
>                 geometry: ls
> Any advice is very appreciated. Thanks in advance
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-Segment-Length-to-Path-tp7029815p7081881.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
