[OpenLayers-Dev] Using MapServer CGI Parameters in OpenLayers
Jayaprakash V jpvalappil at yahoo.com
Thu Feb 3 00:52:11 EST 2011
Hi All,
I am a newbie developer in OpenLayers. I would like to know whether we can use the different CGI Parameters that the Map Server's CGI supports? For eg: consider the following URL
http://…/cgi-bin/mapserv.exe?map=C:/ms4w/apps/FarSystems.map&mode=indexquerymap&qlayer=xxxx&shapeindex=751&mapext=663835+5104010+664125+5104210&layers=aaaaa bbbb cccc&mapsize=780+600
Is it possible to change the map mode in OpenLayers to indexquerymap?
Is it possible to set a query layer?
Is it possible to set shapeindex?
I would appreciate any help in this regard
Thanks
Jayaprakash
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110202/c8b03f5b/attachment.html
More information about the Dev mailing list
