[OpenLayers-Dev] Re: toward better dependency management
Tim Schaub tschaub at opengeo.org
Wed Jan 5 16:03:55 EST 2011
So I've made changes in the trunk to simplify build configurations.
http://trac.osgeo.org/openlayers/changeset/11006/
This allows for circular dependencies (imposing an arbitrary sort
order).  Then I changed things to break the one circular dependency that
we have that cannot be resolved with an arbitrary sort order.
http://trac.osgeo.org/openlayers/changeset/11003/
The result is that dependencies can now be entirely declared within the
library (and, in the future, in your application code).
As a consequence, people using custom build profiles will likely want to
remove the "first" section from their configuration files.
E.g. http://trac.osgeo.org/openlayers/changeset/11008
Hope that makes sense,
Tim
On 1/1/11 4:34 PM, Tim Schaub wrote:
> Hey-
> I'd like to make it easier to correctly build custom profiles of the
> library. One restriction that we currently face is that our toposort
> method is unnecessarily strict with regard to circular dependencies.
> With a more tolerant toposort, we could safely declare more dependencies
> in our source files (where they belong) instead of in configuration files.
> One current circular dependency that will not be satisfied with an
> arbitrary sort order is the Class -> Util -> BaseTypes -> Class loop.
> Our Class function really only requires the extend method from Util. If
> we define the extend method in the Class.js file, then things can be
> resolved properly.
> I've made changes in a sandbox that include a simplified & more tolerant
> topological sort [1], extend in Class instead of Util [2], and proper
> dependency declarations in the source comments. This results in simpler
> build configuration files [3] (closer to something that could be handled
> by @require comments in an application file instead of a separate build
> configuration file).
> I've put up a patch that moves the extend method into Class.js [4]. I
> thought this one deserved review & input. All the other changes are
> comments only or changes in the build tools.
> Thanks for any feedback,
> Tim
> [1] http://trac.osgeo.org/openlayers/changeset/10979/
> [2] http://trac.osgeo.org/openlayers/changeset/10982/
> [3]
> http://trac.osgeo.org/openlayers/browser/sandbox/tschaub/uncircular/build/lite.cfg
> [4] http://trac.osgeo.org/openlayers/ticket/2992
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
