[OpenLayers-Dev] Re: toward better dependency management
XinGang Li
slinavlee at gmail.com
Thu Jan 6 20:25:56 EST 2011
I like to see this changes, but may be we need more, I think it's the time
to move the indexOf and toFloat methods from Util to base types.
For backward compatibility, we let OpenLayers.Util.indexOf link to
OpenLayers.Array.indexOf
Li XinGang
EMail: slinavlee at gmail.com
Blog: avlee.cnblogs.com
Site: www.mapboost.org
On Thu, Jan 6, 2011 at 5:03 AM, Tim Schaub <tschaub at opengeo.org> wrote:
> So I've made changes in the trunk to simplify build configurations.
> http://trac.osgeo.org/openlayers/changeset/11006/
> This allows for circular dependencies (imposing an arbitrary sort order).
> Then I changed things to break the one circular dependency that we have
> that cannot be resolved with an arbitrary sort order.
> http://trac.osgeo.org/openlayers/changeset/11003/
> The result is that dependencies can now be entirely declared within the
> library (and, in the future, in your application code).
> As a consequence, people using custom build profiles will likely want to
> remove the "first" section from their configuration files.
> E.g. http://trac.osgeo.org/openlayers/changeset/11008
> Hope that makes sense,
> Tim
> On 1/1/11 4:34 PM, Tim Schaub wrote:
>> Hey-
>> I'd like to make it easier to correctly build custom profiles of the
>> library. One restriction that we currently face is that our toposort
>> method is unnecessarily strict with regard to circular dependencies.
>> With a more tolerant toposort, we could safely declare more dependencies
>> in our source files (where they belong) instead of in configuration files.
>> One current circular dependency that will not be satisfied with an
>> arbitrary sort order is the Class -> Util -> BaseTypes -> Class loop.
>> Our Class function really only requires the extend method from Util. If
>> we define the extend method in the Class.js file, then things can be
>> resolved properly.
>> I've made changes in a sandbox that include a simplified & more tolerant
>> topological sort [1], extend in Class instead of Util [2], and proper
>> dependency declarations in the source comments. This results in simpler
>> build configuration files [3] (closer to something that could be handled
>> by @require comments in an application file instead of a separate build
>> configuration file).
>> I've put up a patch that moves the extend method into Class.js [4]. I
>> thought this one deserved review & input. All the other changes are
>> comments only or changes in the build tools.
>> Thanks for any feedback,
>> Tim
>> [1] http://trac.osgeo.org/openlayers/changeset/10979/
>> [2] http://trac.osgeo.org/openlayers/changeset/10982/
>> [3]
>> http://trac.osgeo.org/openlayers/browser/sandbox/tschaub/uncircular/build/lite.cfg
>> [4] http://trac.osgeo.org/openlayers/ticket/2992
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110107/0ba021e0/attachment.html
More information about the Dev
