[OpenLayers-Dev] Re: [Openlayers-Users] Map data popups on Google overlays
Martin Saturka martin.saturka at sourcefabric.org
Wed Jan 5 16:09:33 EST 2011
>> 2) Putting the Bing layer into base layers causes event horrible
>> problems. When I click on a pop-up window, that pop-up window takes it
>> as a close event, and together with it puts a that clicking into the
>> map, even though close events are ended at the pop-up closing methods.
>> This mayhem only starts after some time (a few minutes) of map moving
>> and poi / pop-up clicking, thus it may be a reason why it was not
>> noticed.
> Are you sure that this only happens with the Bing layer? Anyway, can you also please provide a minimal example that shows the issue?
It only happens when the Bing layer is created and put into the map
base layers. Then it happens, when a different base layer is used.
When the Bing layer is not put into the map base layers (even when it
is created), all is ok.
I'm sorry, having a lack of time now, but I will test the previously
mentioned patch, and will create an example (I hope at some few days).
M.
Martin Saturka
Software Engineer, Sourcefabric
www.sourcefabric.org
More information about the Dev mailing list
