[OpenLayers-Dev] (no subject)
    Roald de Wit
    list at rdewit.net
    Mon Jan 10 16:42:15 EST 2011
Please send your question to the OL *Users* list [1] as you are *using*
OL for developing your own application. This is a mailing list for OL
*Developers*:
"Developers mailing list for OpenLayers. Ideal if you're modifying
OpenLayers classes, creating subclasses, or otherwise getting into the
guts of OpenLayers."
Plus: make sure you use a (relevant) subject when sending an email to
the list.
Regards, Roald
[1] http://lists.osgeo.org/mailman/listinfo/openlayers-users
On 11/01/11 01:23, carlos wrote:
> Hi all!!!
> I had this function, in order to, add markers to my map.
> function addMarker(ll, popupClass, popupContentHTML, closeBox, overflow) {
> var feature = new OpenLayers.Feature(markers, ll);
> feature.closeBox = closeBox;
> feature.popupClass = popupClass;
> feature.data.popupContentHTML = popupContentHTML;
> feature.data.overflow = (overflow) ? "auto" : "hidden";
> var marker = feature.createMarker();
> var size = new OpenLayers.Size(25,25);
> var offset = new OpenLayers.Pixel(-12, -24);
> var icon = new
> OpenLayers.Icon('http://www.openlayers.org/dev/img/marker-blue.png',
> size, offset);
> marker.icon = icon;
> var markerClick = function (evt) {
> if (this.popup == null) {
> this.popup = this.createPopup(this.closeBox);
> map.addPopup(this.popup);
> this.popup.show();
> } else {
> this.popup.toggle();
> currentPopup = this.popup;
> OpenLayers.Event.stop(evt);
> marker.events.register("mousedown", feature, markerClick);
> markers.addMarker(marker);
> I have a problem with the icon of the marker. If I put an icon the
> event mousedown don’t work. The pop-up of my marker don't appear.
> There is any trouble with that?
> Thanks!!!
> */Carlos Domínguez/*
> /Área de Proyectos/
> /Tfno: +34 948312156/
> www.geoactio.com <http://www.geoactio.com/>
> Polígono Industrial Mocholi
> Edificio CEIN, Nave A2
> 31110 Noáin (Navarra) SPAIN
> La información que contiene este correo electrónico es confidencial.
> Si Vd. ha recibido esta comunicación por error, por favor notifíquelo
> inmediatamente al remitente y bórrelo. Antes de imprimir este mensaje,
> asegúrese de que es necesario. El medio ambiente está en nuestra mano.
> The information contained in this electronic mail is confidential. If
> you have received this mail by error, please immediately notify the
> sender and delete it. Please, consider the environment and do not
> print this email unless it is absolutely necessary.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
