[OpenLayers-Dev] "allow pan while drawing" patch
Andreas Hocevar ahocevar at opengeo.org
Wed Jan 12 07:22:50 EST 2011
Hi Eric,
thanks for your efforts. My only concern is that adding vertices on mouseup instead of mousedown negatively affects the user experience when a Snapping control is used. This is because the user doesn't see any more where the vertex is going to be snapped to.
At this point, I have no idea how to solve this.
Andreas.
On Jan 12, 2011, at 13:05 , Eric Lemoine wrote:
> Hello
> Currently the map cannot be panned when a draw feature control is
> active. Google Maps allows it, and I think it would be great that
> OpenLayers allow it as well.
> I've started prototyping this in a sandbox. It currently it works for
> "draw point" and "draw line" only (and it breaks the freehand mode).
> See [1] and [2] for examples.
> With my patch points are added on mouseup as opposed to mousedown, so
> the drawing user experience is changed a bit. Also, although my patch
> makes this somehow configurable (through stopDown stopUp options), I
> think "allow pan while drawing" should be the default.
> What do you think about it? Would such a patch make sense for
> inclusion into the trunk?
> Thanks for any feedback,
> [1] <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/draw-feature.html>
> [2] <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/measure.html>
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
