[OpenLayers-Dev] "allow pan while drawing" patch
Cédric MOULLET cedric.moullet at gmail.com
Thu Jan 13 13:32:12 EST 2011
SO GREAT  !! Thanks a lot for implementing that.
This is really powerful and usable.
Some CAD systems provide also the possibility to snap, for example, at the
intersections of lines (without having a real point) or in the middle of
circle. Usually, the cursor will change depending of the type of snapping.
But this is of course more than a nice to have.
Thanks again !
Cédric
On Thu, Jan 13, 2011 at 3:26 PM, Eric Lemoine
<eric.lemoine at camptocamp.com>wrote:
> On Wed, Jan 12, 2011 at 1:22 PM, Andreas Hocevar <ahocevar at opengeo.org>
> wrote:
> > Hi Eric,
> > thanks for your efforts. My only concern is that adding vertices on
> mouseup instead of mousedown negatively affects the user experience when a
> Snapping control is used. This is because the user doesn't see any more
> where the vertex is going to be snapped to.
> > At this point, I have no idea how to solve this.
> Thanks for explaining.
> Some of us here at Camptocamp have discussed this a bit further, and
> we've come up with a potential solution to this issue, where the first
> point to be laid down is drawn as the soon as the control is active
> (or the previous feature is finalized).
> See the demo on
> http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/snapping.html
> You should have a point following the mouse as soon as the draw tool
> is made active in the toolbar.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Welcome to my world: http://www.cedricmoullet.com/
My Linked In profile: http://www.linkedin.com/in/cedricmoullet
Twitter: http://twitter.com/cedricmoullet
Home sweet home:
http://map.geo.admin.ch/?crosshair=bowl&zoom=11&X=185241.24219&Y=561288.90625&bgOpacity=0&selectedNode=node_ch.swisstopo.fixpunkte-lage1
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110113/761b2d56/attachment.html
More information about the Dev mailing list
