[OpenLayers-Dev] "allow pan while drawing" patch
Claude Philipona claude.philipona at camptocamp.com
Thu Jan 13 10:52:02 EST 2011
Hi Eric,
I think this is just perfect in term of usability. Nice job Eric.
Claude
On Thu, Jan 13, 2011 at 15:26, Eric Lemoine <eric.lemoine at camptocamp.com> wrote:
> On Wed, Jan 12, 2011 at 1:22 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Hi Eric,
>> thanks for your efforts. My only concern is that adding vertices on mouseup instead of mousedown negatively affects the user experience when a Snapping control is used. This is because the user doesn't see any more where the vertex is going to be snapped to.
>> At this point, I have no idea how to solve this.
> Thanks for explaining.
> Some of us here at Camptocamp have discussed this a bit further, and
> we've come up with a potential solution to this issue, where the first
> point to be laid down is drawn as the soon as the control is active
> (or the previous feature is finalized).
> See the demo on
> <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/snapping.html>.
> You should have a point following the mouse as soon as the draw tool
> is made active in the toolbar.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Camptocamp SA
Claude Philipona
PSE-A
CH-1015 Lausanne
Switzerland
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
+41 21 619 10 11 (direct)
+41 78 648 32 84 (mobile)
+33 4 79 44 44 96 (france)
More information about the Dev mailing list
