[OpenLayers-Dev] "allow pan while drawing" patch
Eric Lemoine eric.lemoine at camptocamp.com
Thu Jan 13 09:26:16 EST 2011
On Wed, Jan 12, 2011 at 1:22 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi Eric,
> thanks for your efforts. My only concern is that adding vertices on mouseup instead of mousedown negatively affects the user experience when a Snapping control is used. This is because the user doesn't see any more where the vertex is going to be snapped to.
> At this point, I have no idea how to solve this.
Thanks for explaining.
Some of us here at Camptocamp have discussed this a bit further, and
we've come up with a potential solution to this issue, where the first
point to be laid down is drawn as the soon as the control is active
(or the previous feature is finalized).
See the demo on
<http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/snapping.html>.
You should have a point following the mouse as soon as the draw tool
is made active in the toolbar.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
