[OpenLayers-Dev] Re: Patch for Ticket #2754
Roald de Wit list at rdewit.net
Fri Jan 14 05:38:48 EST 2011
Hi Senthil,
You've sent your email to the correct list. However, whether or not
action is taken upon a ticket someone creates depends on a number of
factors like:
- the completeness of the patch: does it have tests and do all other
tests still pass in the major browsers when patch is applied?
- the seriousness of the bug or usefulness of the feature, ie: does it
affect many people
- the work load of the OL developers
- and more
It might be somewhat frustrating when you don't see action taken quick
enough (in your opinion).
In your case, sending an email to the list without any explanation in it
(like describing the problem and the solution) is not too helpful: the
reader is forced to click on the link to trac to find out what the
ticket is about.
The good news is: your ticket is in trac you've set the milestone 2.11.
It's now best to wait until someone from the core dev team will assess
the patch and possibly commit it to trunk in time for the next version.
Quite often, shortly before a new release the developers go through all
outstanding tickets.
In the meanwhile, I suggest to just sit back and relax. You can always
apply your patch to your local OL version, just like everybody else
who's problem might be solved with your patch.
I hope that helps a bit.
Regards,
Roald
On 14/01/11 21:01, Senthil wrote:
> Hi all
>   I could not see any response for patch. And even not much email
> traffic in dev mailing list. I wonder whether i am using correct
> mailing list.  Pls any one in this mailing list, let me know the
> procedure to submit the patch and if any other mailing list there
> Thanks
> regards
> Senthil
> On Sun, Jan 9, 2011 at 12:26 AM, Senthil <senthilruban at gmail.com
> <mailto:senthilruban at gmail.com>> wrote:
>     Hi all,
>       I have attached patch for ticket 2754
>     (http://trac.osgeo.org/openlayers/ticket/2754). Refer the ticket
>     for detail about the issue and fixes too.
>       I wish to see the patch applied to next release which help me to
>     use the release than patching to new releases.
>       Pls let me know if there are clarification on patch.
>     Thanks
>     regards
>     Senthil
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
