[OpenLayers-Dev] Re: Patch for Ticket #2754
Senthil
senthilruban at gmail.com
Fri Jan 14 06:02:57 EST 2011
Hi Roald
Thanks for your email.
Hope you have seen that ticket open in 6 months back and tried different
ways to fix the issues (with geowebcache initially). Recently only found
that issue in Openlayers. It would be easy for reviewer to read from ticket
to understand exact cause. That is the reason i did not tried to repeat in
email.
If this fix can included to next release of 2.11, i am happy wait till.
Thanks again for quick response
regards
Senthil
On Fri, Jan 14, 2011 at 11:38 PM, Roald de Wit <list at rdewit.net> wrote:
> Hi Senthil,
> You've sent your email to the correct list. However, whether or not action
> is taken upon a ticket someone creates depends on a number of factors like:
> - the completeness of the patch: does it have tests and do all other tests
> still pass in the major browsers when patch is applied?
> - the seriousness of the bug or usefulness of the feature, ie: does it
> affect many people
> - the work load of the OL developers
> - and more
> It might be somewhat frustrating when you don't see action taken quick
> enough (in your opinion).
> In your case, sending an email to the list without any explanation in it
> (like describing the problem and the solution) is not too helpful: the
> reader is forced to click on the link to trac to find out what the ticket is
> about.
> The good news is: your ticket is in trac you've set the milestone 2.11.
> It's now best to wait until someone from the core dev team will assess the
> patch and possibly commit it to trunk in time for the next version. Quite
> often, shortly before a new release the developers go through all
> outstanding tickets.
> In the meanwhile, I suggest to just sit back and relax. You can always
> apply your patch to your local OL version, just like everybody else who's
> problem might be solved with your patch.
> I hope that helps a bit.
> Regards,
> Roald
> On 14/01/11 21:01, Senthil wrote:
>> Hi all
>> I could not see any response for patch. And even not much email traffic
>> in dev mailing list. I wonder whether i am using correct mailing list. Pls
>> any one in this mailing list, let me know the procedure to submit the patch
>> and if any other mailing list there
>> Thanks
>> regards
>> Senthil
>> On Sun, Jan 9, 2011 at 12:26 AM, Senthil <senthilruban at gmail.com <mailto:
>> senthilruban at gmail.com>> wrote:
>> Hi all,
>> I have attached patch for ticket 2754
>> (http://trac.osgeo.org/openlayers/ticket/2754). Refer the ticket
>> for detail about the issue and fixes too.
>> I wish to see the patch applied to next release which help me to
>> use the release than patching to new releases.
>> Pls let me know if there are clarification on patch.
>> Thanks
>> regards
>> Senthil
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110115/7d6d0a8f/attachment.html
More information about the Dev
