[OpenLayers-Dev] Advanced Closure Compiler for OpenLayers: lite.cfg
= 46 kb
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Mon Jan 17 08:08:55 EST 2011
Hi developers,
OpenLayers is not ready to use Closure Compiler ADVANCED_OPTIMIZATIONS.
Now the resulting code fails.
With adjustments in the source, the resulting code can run, and the
result is: 46 kb for lite.cfg, less than 40% of "jsmin" try
http://xamamano.appspot.com/ol/46kb/example.html this
(with basic changes get 57kb, see
http://code.google.com/intl/ca/closure/compiler/docs/api-tutorial3.html#propnames
Inconsistent Property Names ;
and with more work is obtained 46kb, see "very pure javascript"
in
http://osgeo-org.1803224.n2.nabble.com/OpenLayers-without-warnings-using-the-Closure-Compiler-in-VERBOSE-mode-tc5916529.html
OpenLayers without warnings... )
I have several reasons to believe that the use of advanced optimizations
is inappropriate to distribute the OpenLayers code.
ADVANCED_OPTIMIZATIONS can only be suitable for building customized
projects, but currently is unbeatable in this area.
NOTE: All calculations are not including the license (5kb)
Regards,
Xavier Mamano
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Advanced-Closure-Compiler-for-OpenLayers-lite-cfg-46-kb-tp5931700p5931700.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
