[OpenLayers-Dev] Advanced Closure Compiler for OpenLayers: lite.cfg = 46 kb
Paul Spencer pspencer at dmsolutions.ca
Mon Jan 17 08:42:51 EST 2011
Impressive improvement, thanks for the amazing work you are doing with this.
Cheers
Paul
On 2011-01-17, at 8:08 AM, Xavier Mamano (jorix) wrote:
> Hi developers,
> OpenLayers is not ready to use Closure Compiler ADVANCED_OPTIMIZATIONS.
> Now the resulting code fails.
> With adjustments in the source, the resulting code can run, and the
> result is: 46 kb for lite.cfg, less than 40% of "jsmin" try
> http://xamamano.appspot.com/ol/46kb/example.html this
> (with basic changes get 57kb, see
> http://code.google.com/intl/ca/closure/compiler/docs/api-tutorial3.html#propnames
> Inconsistent Property Names ;
> and with more work is obtained 46kb, see "very pure javascript"
> in
> http://osgeo-org.1803224.n2.nabble.com/OpenLayers-without-warnings-using-the-Closure-Compiler-in-VERBOSE-mode-tc5916529.html
> OpenLayers without warnings... )
> I have several reasons to believe that the use of advanced optimizations
> is inappropriate to distribute the OpenLayers code.
> ADVANCED_OPTIMIZATIONS can only be suitable for building customized
> projects, but currently is unbeatable in this area.
> NOTE: All calculations are not including the license (5kb)
> Regards,
> Xavier Mamano
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Advanced-Closure-Compiler-for-OpenLayers-lite-cfg-46-kb-tp5931700p5931700.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
   Paul Spencer
   Chief Technology Officer
   DM Solutions Group Inc
   http://research.dmsolutions.ca/
More information about the Dev mailing list
