[OpenLayers-Dev] Re: Advanced Closure Compiler for OpenLayers: lite.cfg = 46 kb
Xavier Mamano (jorix) xavier.mamano at gmail.com
Mon Jan 17 12:51:02 EST 2011
Hi Paul,
Thanks for breaking the silence!
Yes this is an impressive result but now ADVANCED_OPTIMIZATIONS application
has a more academic than practical character. I have only made the changes
necessary to lite.cfg work.
(and I could see that it is essential to use the
http://code.google.com/intl/ca/closure/compiler/docs/inspector.html Closure
Inspector )
On the other hand SIMPLE_OPTIMIZATIONS is directly applicable, is safe and
has good compression ratio of 20%.
But it is also remarkable that the compiler gives useful information when it
checks
the source code, see #2960, #2971, #2976,
http://trac.osgeo.org/openlayers/ticket/3001 #3001  and
http://trac.osgeo.org/openlayers/ticket/2989 #2989 .
Solve massive warnings highlights what should be revised. This has
been my main line of work done with Closure Compiler for OpenLayers,
see:  http://trac.osgeo.org/openlayers/ticket/3008 #3008  and also
http://osgeo-org.1803224.n2.nabble.com/OpenLayers-without-warnings-using-the-Closure-Compiler-in-VERBOSE-mode-tc5916529.html
OpenLayers without warnings...
Thanks for any feedback
Regards,
Xavier
Paul Spencer-2 wrote:
> Impressive improvement, thanks for the amazing work you are doing with
> this.
> Cheers
> Paul
> On 2011-01-17, at 8:08 AM, Xavier Mamano (jorix) wrote:
>> Hi developers,
>> OpenLayers is not ready to use Closure Compiler ADVANCED_OPTIMIZATIONS.
>> Now the resulting code fails.
>> With adjustments in the source, the resulting code can run, ...
> __________________________________________
>    Paul Spencer
>    Chief Technology Officer
>    DM Solutions Group Inc
>    http://research.dmsolutions.ca/
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Advanced-Closure-Compiler-for-OpenLayers-lite-cfg-46-kb-tp5931700p5932647.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
