[OpenLayers-Dev] Re: "allow pan while drawing" patch
Andreas Hocevar
ahocevar at opengeo.org
Tue Jan 18 11:47:50 EST 2011
I think that this is awesome! I haven't looked at the code, but I'd say if it doesn't change any API behavior we rely on currently (like when the sketch layer is added, when events are fired), this would be a great addition to trunk, and should not live a poor life in an addin.
Thanks!
Andreas.
On Jan 18, 2011, at 17:01 , Eric Lemoine wrote:
> On Thu, Jan 13, 2011 at 10:32 PM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
>> On Thursday, January 13, 2011, Tim Schaub <tschaub at opengeo.org> wrote:
>>> I should add. I'll be interested to hear what you think about supporting freehand and snapping together. This is a combination of functionality that we're relying on.
>> When drawing in freehand mode (for example with the freehand modifier
>> key pressed) we could just dynamically make "pan while drawing"
>> ineffective. So the freehand snapping combination would pretty much
>> work like today.
> The examples at
> <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/draw-feature.html>
> and exemplifies this.
> My patch alters the user experience - points are added on mouseup, and
> a point is drawn on activate. Given that I'm happy to create new
> handlers, and place them in a new addin. This addin could be used as
> an incubation home, and inclusion into the lib could be considered
> later, for OpenLayers 3 for example.
> Thank you for any comment,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
