[OpenLayers-Dev] Re: "allow pan while drawing" patch
Tim Schaub
tschaub at opengeo.org
Wed Jan 19 13:26:01 EST 2011
On 1/18/11 9:01 AM, Eric Lemoine wrote:
> On Thu, Jan 13, 2011 at 10:32 PM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
>> On Thursday, January 13, 2011, Tim Schaub<tschaub at opengeo.org> wrote:
>>> I should add. I'll be interested to hear what you think about supporting freehand and snapping together. This is a combination of functionality that we're relying on.
>> When drawing in freehand mode (for example with the freehand modifier
>> key pressed) we could just dynamically make "pan while drawing"
>> ineffective. So the freehand snapping combination would pretty much
>> work like today.
> The examples at
> <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/draw-feature.html>
> and exemplifies this.
> My patch alters the user experience - points are added on mouseup, and
> a point is drawn on activate. Given that I'm happy to create new
> handlers, and place them in a new addin. This addin could be used as
> an incubation home, and inclusion into the lib could be considered
> later, for OpenLayers 3 for example.
I think this looks excellent and deserves a home in the trunk. I'm sure
there will be things to work through in editing applications. I'd
suggest that we should put out a wide requests for reviews based on a
completed patch.
Thanks for the work on this. I look forward to testing it out in a few
applications.
Tim
> Thank you for any comment,
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
