[OpenLayers-Dev] SOS Capabilities through POST (XML data)
Bart van den Eijnden
bartvde at opengeo.org
Thu Jan 20 07:02:01 EST 2011
Hi Xurxo,
great news!
Please create the appropriate tickets with patches.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Jan 20, 2011, at 12:52 PM, Xurxo Mendez wrote:
> Hi all,
> I'm working with a SOS server that only allows GetCapabilities with POST parameters (not KVP allowed in GET query String). I've added some writers to lib/OpenLayers/Format/SOSCapabilities/v1_0_0.js and lib/OpenLayers/Format/OWSCommon/v1.js to support this. You can check this in my sandbox (http://trac.openlayers.org/browser/sandbox/sonxurxo/sos).
> If you consider that this can be matter of a ticket I can create it and attach a patch.
> I've also created an example using this feature, that also (this might be interesting for Bart I hope) retrieves the feature geometries (points) of the FOIs directly through a GetObservation request, which is mandatory in the standard, instead of doing so through a GetFeatureOfInterest (optional in the standard). You can test it also in my sandbox as well, at examples/SOSGetObservation.html.
> Best regards,
> Xurxo Méndez Pérez
> http://www.sonxurxo.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110120/4f06ac79/attachment.html
More information about the Dev
