[OpenLayers-Dev] script protocol and filter serialization
Tim Schaub
tschaub at opengeo.org
Thu Jan 27 16:49:57 EST 2011
Good to know Chris. Thanks for the reply. I did check the Feature
Server docs to see if this filter syntax was used there as well. Guess
I didn't dig enough.
I agree that it deserves a better name if used more widely. Since it is
the default for the HTTP protocol, we could call it simply
httpFilterSerializer or olFilterSerializer.
I'm happy to make the changes if anybody else has suggestions.
Tim
On 1/27/11 2:15 PM, christopher.schmidt at nokia.com wrote:
> Tim,
> MapFish and FeatureServer use essentially the same filter parameters, and at the
> time, when we discussed it on the mailing list, it seemed a simple enough convention
> that backing it into HTTP (to be subclassed/replaced by higher level protocols)
> wasn't a big deal.
> I'm not aware of anyone actively using Filters with FeatureServer, so I have no
> investment in keeping it the way it is, but I do think that tying it to MapFish
> is a bit narrow; I don't have a better suggestion at the moment.
> -- Chris
> On Jan 27, 2011, at 4:03 PM, ext Tim Schaub wrote:
>> Hey-
>> I posted a link a while ago to a working Script protocol for reading features cross-origin.
>> http://dev.openlayers.org/sandbox/tschaub/xdomain/examples/cross-origin.html
>> Pierre jumped in and helped out by writing tests (thanks for that). The other changes he made prompted a question for me about the filterToParams method in the HTTP protocol (something that has nagged me for a while actually).
>> Summarized here: http://trac.osgeo.org/openlayers/ticket/2956#comment:4
>> Basically, I think we should not go too far with this custom method of serializing a filter in a query string. I'm pretty sure this is a MapFish specific convention (but could be wrong about that).
>> I also think it makes sense to let app devs provide their own simple filterToParams methods (I've done this in the updated cross-origin.html example).
>> Further, I think we could provide additional conventions for serializing filters in the library. I think it would make sense to support CQL/ECQL for example. I also think we could have a simple Open Search (with Geo extension) filter serializer. All of these should be named like the conventions or standards they represent.
>> Following this, I think it makes sense to name the current filterToParams method what it is. I've proposed OpenLayers.Protocol.mapFishFilterSerializer in this ticket:
>> http://trac.osgeo.org/openlayers/ticket/3032
>> Thanks for any feedback,
>> Tim
>> PS - The updated Script protocol ticket is also review-ready: http://trac.osgeo.org/openlayers/ticket/2956
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Tim Schaub
More information about the Dev
