[OpenLayers-Dev] Re: How to override abstract
OpenLayers.Protocol.WFS.v1?
Tim Schaub
tschaub at opengeo.org
Fri Jul 1 13:30:21 EDT 2011
This does what I'd expect:
var orig = OpenLayers.Protocol.WFS.v1.prototype.handleRead;
OpenLayers.Util.extend(OpenLayers.Protocol.WFS.v1.prototype, {
handleRead: function(response, options) {
alert("handleRead");
orig.apply(this, arguments);
Does it for you?
Tim
On 6/30/11 3:39 PM, myOpenLayersUName wrote:
> Hi Tim,
> Thank you for your response. Yes, I was able to get your simple case to
> work. Further, I was able to load this:
> foo: "bar"
> ,blah: function(){
> alert(this.foo);
> And, within the real OpenLayers.Protocol.WFS.v1.handleRead function, I added
> a call to this.blah() and at runtime, the alert with "bar" appeared.
> However, when I try to override an existing function I don't seem able to do
> it.
> Continuing with my example above, if I removed the this.blah() call that I
> added in the real OpenLayers.Protocol.WFS.v1.handleRead function (so it's
> back to its distribution form) and updated my own file as follows:
> foo: "bar"
> ,blah: function(){
> alert(this.foo);
> ,handleRead: function(response, options) {
> this.blah();
> if(options.callback) {
> var request = response.priv;
> if(request.status>= 200&& request.status< 300) {
> // success
> response.features = this.parseFeatures(request);
> response.code = OpenLayers.Protocol.Response.SUCCESS;
> } else {
> // failure
> response.code = OpenLayers.Protocol.Response.FAILURE;
> options.callback.call(options.scope, response);
> At runtime, my handleRead is not run and I don't see the alert with "bar" in
> it.
> When I step through the OpenLayers.Util.extend function, it sure looks like
> my handleRead is overwriting the distributed one but at runtime it's
> definitely not using it.
> I really don't get what the problem could be here.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-override-abstract-OpenLayers-Protocol-WFS-v1-tp6534072p6535084.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Tim Schaub
OpenGeo - http://opengeo.org
Enterprise support for open source geospatial.
More information about the Dev
