[OpenLayers-Dev] Compressor used in the openlayers release version?
Phil Scadden p.scadden at gns.cri.nz
Tue Jul 5 17:45:42 EDT 2011
> The examples available at<http://www.openlayers.org/dev/examples/>
> now rely on OpenLayers builds compressed with the Google Closure
> compiler.
Any idea why, when I use the closure compiler, command line is:
build.py -c closure full OpenLayers-closure.js
I get this (after merging libraries)
Compressing using closure
java.io.FileNotFoundException:
c:\docume~1\scaddenp\locals~1\temp\tmpfoewdx (The
  process cannot access the file because it is being used by another
process)
         at java.io.FileOutputStream.open(Native Method)
         at java.io.FileOutputStream.<init>(Unknown Source)
         at
com.google.javascript.jscomp.AbstractCommandLineRunner.filenameToOutp
utStream(Unknown Source)
         at
com.google.javascript.jscomp.AbstractCommandLineRunner.fileNameToOutp
utWriter(Unknown Source)
         at
com.google.javascript.jscomp.AbstractCommandLineRunner.doRun(Unknown
Source)
         at
com.google.javascript.jscomp.AbstractCommandLineRunner.run(Unknown So
urce)
         at com.google.javascript.jscomp.CommandLineRunner.main(Unknown
Source)
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev mailing list
