[OpenLayers-Dev] Re: mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Andreas Hocevar ahocevar at opengeo.org
Wed Jul 13 03:20:24 EDT 2011
here's the diff: http://bit.ly/nEFarh
Only the mobile-jq.js file has changed. Hope this helps.
Regards,
Andreas.
On Wed, Jul 13, 2011 at 2:49 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Andreas,
>> the mobile-jq example on trunk is now updated to also work with newer
>> versions of JQuery Mobile. Note that the example still uses the same
>> version it used to, beause the fixContentHeight workaround does not
>> work properly in later versions.
>> Anyway, starting from the current mobile-jq example, people can update
>> their applications. And maybe somebody can investigate how to properly
>> size the content now.
> I just checkout the svn.
> svn checkout http://svn.openlayers.org/trunk/openlayers/
> So, what have been change in the mobile-jq example?
> I am totally lost here. I could see any changes, what files I should be looking?
> Could please post the name of the files that has been updated and the codes?
> Thanks.
> Noli
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
