[OpenLayers-Dev] Re: mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Noli Sicad nsicad at gmail.com
Tue Jul 12 20:49:36 EDT 2011
Hi Andreas,
> the mobile-jq example on trunk is now updated to also work with newer
> versions of JQuery Mobile. Note that the example still uses the same
> version it used to, beause the fixContentHeight workaround does not
> work properly in later versions.
> Anyway, starting from the current mobile-jq example, people can update
> their applications. And maybe somebody can investigate how to properly
> size the content now.
I just checkout the svn.
svn checkout http://svn.openlayers.org/trunk/openlayers/
So, what have been change in the mobile-jq example?
I am totally lost here. I could see any changes, what files I should be looking?
Could please post the name of the files that has been updated and the codes?
Thanks.
Noli
More information about the Dev mailing list
