[OpenLayers-Dev] OL trunk + MapServer 6.0 + BBOX Strategy -> WFS server error. Invalid or Unsupported FILTER in GetFeature
Andreas Hocevar ahocevar at opengeo.org
Sat Jul 16 05:59:32 EDT 2011
Hey Roald,
the PropertyName will still always be set, unless you have a poorly
configured WFS protocol (i.e. no FeatureNS set).
How is your protocol configured (the one that used to work in 2.10, but does
not any more)? Maybe we find a better way to determine poorly configured
protocols.
FYI, the offending change came with
http://trac.osgeo.org/openlayers/ticket/3368
Andreas.
On Jul 16, 2011 8:25 AM, "Roald de Wit" <list at rdewit.net> wrote:
When trying out one of my apps with OL trunk, I get the following error:
"WFS server error. Invalid or Unsupported FILTER in GetFeature". Whilst
digging through the code, I noticed that the WFS requests have changed: the
PropertyName tag has been removed from the BBOX Filter.
It seems possible to work around the problem by providing a 'property'
attribute to the BBOX filter, but since I use a WFS protocol with a BBOX
Strategy, this strategy does not allow me to add this attribute to the
filter without overriding the createFilter method.
It looks like this change is not in OL 2.11-RC1 but if RC2 will be a
re-branch from trunk (as crschmidt suggests in another thread), then this
could cause problems for people using MS 6.0.x with OL 2.11.
Alexandre Dube reported the same error on the MS trac a few days ago:
http://trac.osgeo.org/**mapserver/ticket/3955<http://trac.osgeo.org/mapserver/ticket/3955>.
He might have run into the same problem. Strictly speaking, it seems to be a
MS bug and not an OL one. But what if it takes a long time before this bug
gets fixed? And, could this be classed as a regression, since 2.10 does not
have this problem?
Regards, Roald
______________________________**_________________
Dev mailing list
Dev at lists.osgeo.org
http://lists.osgeo.org/**mailman/listinfo/openlayers-**dev<http://lists.osgeo.org/mailman/listinfo/openlayers-dev>
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110716/723ff638/attachment.html
More information about the Dev mailing list
