[OpenLayers-Dev] OL trunk + MapServer 6.0 + BBOX Strategy -> WFS
server error. Invalid or Unsupported FILTER in GetFeature
Andreas Hocevar
ahocevar at opengeo.org
Sun Jul 17 15:46:29 EDT 2011
Hi Roald,
please let me know http://trac.osgeo.org/openlayers/ticket/3415 looks
good to you - with that patch applied, you should be able to use your
old configuration again, unless you set the protocol version to 1.1.0
(default is 1.0.0), in which case the requirement for a propertyName
in the BBOX filter would come from the MapServer bug
http://trac.osgeo.org/mapserver/ticket/3955.
Andreas.
On Sun, Jul 17, 2011 at 12:41 AM, Roald de Wit <list at rdewit.net> wrote:
> Hey Andreas,
> Thanks, it works again when adding a geometryName to the protocol.
> 2 things:
> 1) this does change behaviour, so it would be important to document it
> clearly in the release notes for 2.11 (if this makes it in there)
> 2) in the comments in ticked #3368, bartvde says:
> "Maybe there is a WFS out there that needs PropertyName, but ignores
> its value for WFS 1.0. But I think we can safely ignore until
> someone files a bug with a case that fails. "
> This is exactly the case for me with MS 6.0.x and 5.6.x too. MS needs a
> PropertyName (can be anything so it seems!) and gives an error if it is
> missing.
> It's a small change for me to add geometryName (or featureNS) to the
> protocol options. I'm just slightly concerned that there are more people out
> there currently only using featurePrefix and featureType that might not
> understand why their requests suddenly fail when using the new WFS protocol
> behaviour.
> Cheers,
> Roald
> On 17/07/11 03:24, Andreas Hocevar wrote:
>> Hey Roald,
>> what you describe is exactly the new expected behavior. However, if you
>> add either a featureNS or a geometryName, things should be working again.
>> Let me know if you still have concerns, or if and where you think this
>> should be better documented. If the former, do you have a suggestion how we
>> could better solve this? Because the intention of the change you suffer from
>> was to make dynamic WFS configuration simpler.
>> Andreas.
>>> On Jul 16, 2011 2:38 PM, "Roald de Wit" <list at rdewit.net
>>> <mailto:list at rdewit.net>> wrote:
>>> Hey Andreas,
>>> It's true that I don't set the FeatureNS. However, I *do* set the
>>> featureType *and* the featurePrefix in my protocol options, which used to be
>>> sufficient.
>>> If you take the wfs-protocol.html example from trunk and replace
>>> featureNS with: featurePrefix: 'topp', you'll see that the PropertyName
>>> disappears from the WFS request (in the BBOX filter).
>>> Is this expected behaviour, ie: can I not use featurePrefix anymore or is
>>> it a bug?
>>> Thanks, Roald
>>> On 16/07/11 19:59, Andreas Hocevar wrote:
>>> > Hey Roald,
>>> > the PropertyName will still always be set, unless you have a
>>> poorly configured ...
>>> >> On Jul 16, 2011 8:25 AM, "Roald de Wit" <list at rdewit.net
>>> <mailto:list at rdewit.net> <mailto:list at rdewit.net
>>> <mailto:list at rdewit.net>>> wrote:
>>> >> H...
>>> Dev at lists.osgeo.org <mailto:Dev at lists.osgeo.org>
>>> <mailto:Dev at lists.osgeo.org <mailto:Dev at lists.osgeo.org>>
>>> >> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>> Dev mailing list
>>> http://lists.o...
> Dev mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
