[OpenLayers-Dev] OL trunk + MapServer 6.0 + BBOX Strategy -> WFS
server error. Invalid or Unsupported FILTER in GetFeature
Andreas Hocevar
ahocevar at opengeo.org
Mon Jul 18 05:01:46 EDT 2011
Hi Roald,
On Mon, Jul 18, 2011 at 2:36 AM, Roald de Wit <list at rdewit.net> wrote:
> Can I safely assume that my problem could not have been caused by a poorly
> configured WFS service on my side and that the WFS 1.0.0 spec really
> requires the PropertyName to be part of the BBOX filter?
Yes, the WFS 1.0 spec demands a PropertyName in the BBOX filter. On a
side note, MapSever should never have worked with your default
Protocol.WFS configuration, unless you had set gml_geometries in your
mapfile metadata to "the_geom". Looks like MapServer requires the
PropertyName, but doesn't respect the value you provide there.
> In other words:
> could you reproduce the error yourself using MapServer?
Yes. See this GET request:
http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=continents&FILTER=%3CFilter%3E%3CBBOX%3E%3Cgml:PropertyName%3Ethe_geom%3C/gml:PropertyName%3E%3Cgml:Box%3E%3Cgml:coordinates%3E16.0,47.0%2016.1,47.1%3C/gml:coordinates%3E%3C/gml:Box%3E%3C/BBOX%3E%3C/Filter%3E
The PropertyName is set to the_geom. But MapServer still returns
Austria correctly, although the geometryName is msGeometry and not
the_geom. But only looking at it from an XML schema validation
perspective, MapServer is right to complain about an invalid filter in
this request:
http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=continents&FILTER=%3CFilter%3E%3CBBOX%3E%3Cgml:Box%3E%3Cgml:coordinates%3E16.0,47.0%2016.1,47.1%3C/gml:coordinates%3E%3C/gml:Box%3E%3C/BBOX%3E%3C/Filter%3E
On the other hand, MapServer should not complain about this request:
http://demo.mapserver.org/cgi-bin/wfs?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=continents&SRSNAME=CRS:84&FILTER=%3CFilter%3E%3CBBOX%3E%3Cgml:Box%3E%3Cgml:coordinates%3E16.0,47.0%2016.1,47.1%3C/gml:coordinates%3E%3C/gml:Box%3E%3C/BBOX%3E%3C/Filter%3E
It is WMS 1.1, the PropertyName is not mandatory.
Andreas.
> On 18/07/11 05:46, Andreas Hocevar wrote:
>> Hi Roald,
>> please let me know http://trac.osgeo.org/openlayers/ticket/3415 looks
>> good to you - with that patch applied, you should be able to use your
>> old configuration again, unless you set the protocol version to 1.1.0
>> (default is 1.0.0), in which case the requirement for a propertyName
>> in the BBOX filter would come from the MapServer bug
>> http://trac.osgeo.org/mapserver/ticket/3955.
>> Andreas.
>> On Sun, Jul 17, 2011 at 12:41 AM, Roald de Wit<list at rdewit.net> wrote:
>>> Hey Andreas,
>>> Thanks, it works again when adding a geometryName to the protocol.
>>> 2 things:
>>> 1) this does change behaviour, so it would be important to document it
>>> clearly in the release notes for 2.11 (if this makes it in there)
>>> 2) in the comments in ticked #3368, bartvde says:
>>> "Maybe there is a WFS out there that needs PropertyName, but ignores
>>> its value for WFS 1.0. But I think we can safely ignore until
>>> someone files a bug with a case that fails. "
>>> This is exactly the case for me with MS 6.0.x and 5.6.x too. MS needs a
>>> PropertyName (can be anything so it seems!) and gives an error if it is
>>> missing.
>>> It's a small change for me to add geometryName (or featureNS) to the
>>> protocol options. I'm just slightly concerned that there are more people
>>> out
>>> there currently only using featurePrefix and featureType that might not
>>> understand why their requests suddenly fail when using the new WFS
>>> protocol
>>> behaviour.
>>> Cheers,
>>> Roald
>>> On 17/07/11 03:24, Andreas Hocevar wrote:
>>>> Hey Roald,
>>>> what you describe is exactly the new expected behavior. However, if you
>>>> add either a featureNS or a geometryName, things should be working
>>>> again.
>>>> Let me know if you still have concerns, or if and where you think this
>>>> should be better documented. If the former, do you have a suggestion how
>>>> we
>>>> could better solve this? Because the intention of the change you suffer
>>>> from
>>>> was to make dynamic WFS configuration simpler.
>>>> Andreas.
>>>>> On Jul 16, 2011 2:38 PM, "Roald de Wit"<list at rdewit.net
>>>>> <mailto:list at rdewit.net>> wrote:
>>>>> Hey Andreas,
>>>>> It's true that I don't set the FeatureNS. However, I *do* set the
>>>>> featureType *and* the featurePrefix in my protocol options, which used
>>>>> to be
>>>>> sufficient.
>>>>> If you take the wfs-protocol.html example from trunk and replace
>>>>> featureNS with: featurePrefix: 'topp', you'll see that the PropertyName
>>>>> disappears from the WFS request (in the BBOX filter).
>>>>> Is this expected behaviour, ie: can I not use featurePrefix anymore or
>>>>> is
>>>>> it a bug?
>>>>> Thanks, Roald
>>>>> On 16/07/11 19:59, Andreas Hocevar wrote:
>>>>> > Hey Roald,
>>>>> > the PropertyName will still always be set, unless you have a
>>>>> poorly configured ...
>>>>> >> On Jul 16, 2011 8:25 AM, "Roald de Wit"<list at rdewit.net
>>>>> <mailto:list at rdewit.net> <mailto:list at rdewit.net
>>>>> <mailto:list at rdewit.net>>> wrote:
>>>>> >> H...
>>>>> Dev at lists.osgeo.org<mailto:Dev at lists.osgeo.org>
>>>>> <mailto:Dev at lists.osgeo.org<mailto:Dev at lists.osgeo.org>>
>>>>> >> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>> _______________________________________________
>>>>> Dev mailing list
>>>>> http://lists.o...
>>> Dev mailing list
> Dev mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
