[OpenLayers-Dev] Re: Compressor used in the openlayers release version?
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Jul 19 17:36:34 EDT 2011
Hi Andreas,
Yes, I understand.
New
http://trac.osgeo.org/openlayers/attachment/ticket/3158/3158-only-bug.patch
proposes to use the compiler launcher used in Closure Library.
This only solves the bug and does not add any feature. The changes are
considerably reduced, but 2 minutes is very little time ;-)
Regards,
Xavier
Andreas Hocevar-2 wrote:
> Xavier,
> as the review comment says: your patch does way more than fixing the
> Windows build issue, and it is too complex to review. The only thing
> that would help to bring this into 2.11 would be a patch that can be
> reviewed in 2 minutes.
> Andreas.
> On Wed, Jul 6, 2011 at 11:54 PM, Xavier Mamano (jorix)
> <xavier.mamano at gmail.com> wrote:
>> Thanks Phil,
>> I would like to convince the OpenLayers team to move this patch from 2.12
>> to
>> 2.11. I hope your positive evaluation helps, thanks!
>> Xavier Mamano
>> Phil Scadden wrote:
>>> Thanks Xavier
>>>>There is a bug, now "build.py -c closure" does not work on Windows
systems
>>>>(With Linux there is no problem).
>>> Mucking with python, I realised it was windows bug and rewrote with some
>>> pretty ugly workarounds. This patch is a lot more elegant.
>>> Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
>>> Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477
>>> 5232
>>> Notice: This email and any attachments are confidential. If received in
>>> error please destroy and immediately notify us. Do not copy or disclose
>>> the contents.
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Compressor-used-in-the-openlayers-release-version-tp6534884p6556189.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compressor-used-in-the-openlayers-release-version-tp6534884p6600439.html
More information about the Dev mailing list
