[OpenLayers-Dev] Re: Possible bug with Protocol.HTTP
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Jun 15 00:46:18 EDT 2011
On Tue, Jun 14, 2011 at 11:56 PM, codydjango <codydjango at gmail.com> wrote:
> In this case your callback isn't called because of the Fixed strategy.
>> The strategy calls protocol.read and provides its own callback to the
>> read method, so this overrides the "global" callback. If your app code
>> does protocol.read() somewhere then your "global" callback func will
>> get invoked.
> Hello -- I'm new to openlayers, and I've been running into some issues,
> probably because I'm new. One of the first things I wanted to do was draw a
> box, have the server return all the features in the box, and then "do
> something" with them.
> I thought I'd use something like this:
> var getFeatures = new OpenLayers.Control.GetFeature({
> box: true,
> click: false,
> multiple: true,
> protocol: new OpenLayers.Protocol.HTTP({
> url: '/obj',
> format: new OpenLayers.Format.GeoJSON(),
> params: {
> limit: 2000
> What is the best way to set a custom callback to go off once their is
> response data to work with?
The control triggers "featuresselected" events when features are received.
box: true,
click: false,
multiple: true,
url: '/obj',
params: {
limit: 2000
eventListeners: {
featuresselected: function(e) {
// do something with e.features
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
